Air bag steering wheel removal
Hi
does anyone have or know where theres a write up on removing the series 2 air bag steering wheel?
ive done a search on here but found no info for the air bag steering wheel
any info greatly appreciated
cheers
si
Hi Bud, I`ve just done mine, Its quite simple, but you need a specialist tool, Firstly remove the leads from the battery! that stops the bag blowing if anything short circuits, there are 2 small plastic covers either side of the steering wheel, remove them with a screwdriver, under those covers there are 2 torx screws, iirc they are about 8mm but i will check for you, remove the 2 screws, this then releases the airbag unit and it simply pulls out from the steering wheel! unclip all the wires and block connectors, then you need to undo the nut that holds the steering wheel in place, about 30mm but i will check again for you, the steering wheel should then pull off, I`ve probably missed something but its quite easy with the right tools
Daz
Nice one mate cheers
I`m just taking some pics of tools/ ect, give me 5 mins and i will post them up Si :wink:
Hi Bud, to remove the torx screw`s you need a T50 size head, heres some snaps, hope they help
No worries. Glad to help. :hammer: :lol:
Are you on drugs?:lol: Or just happy coz its your birthday? I bet you`ve had 2 shandys and your pissed :laugh::laugh:
Random but, is it possible to fit and have the function of the airbag from the series 2 into the series 1? or is there a shed load of wiring and sensors involved which makes it silly?.. just curious if anyone knows.. cheers
What an informative post by Dazvert.And Easy to follow pics.
This needs to go in the FAQ section with all the "Car Mad " crap removed.
Perhaps a mod can have a look???
Thanks Pete, Yeh Ban him!!!!! :lol::lol:
This place would`nt be the same without him though!! :sailor:
Daz
19mm nut Daz securing the wheel ;)
  • 6 years later...
An old thread I know, but safety first.
The '96 FSM covers the Airbag system and safety precautions when handling the airbag assembly - in particular
not storing and handling the airbag in the "face down" position. In the event of accidental deployment it would turn
the steering wheel into a projectile, sending it up towards the person handling it.
Additionally, the two pins in the airbag connector can be shorted together to remove the chance of an electrical (static)
discharge setting off the airbag.
. I should store it how? I have the bag on my piano face down now! The steering wheel is seperated from it..
