Couple of questions on dash lights
Hi guys, i just got myself a beast of a zed, its immense. But i was after some insight on the lights on the dash.
Its got a switch on the right cluster im thinking thats for a rear fog that i dont have.
When i drive its got HICAS illuminated, does that mean its on and working or does it need attention.
When i turn ignition on i get a gearbox light with check through it, does that mean, check it or it needs to be checked.
And what do the 2 buttons next to off on the air con part do?
Thanks guys
Mark
Fog light button is for front fogs if its a jap import.
Hicas light means either a fault with the system, or low power steering fluid usually this.
Eco when lit means the air con is not in use, and the other one is recirculation, so air is not drawn from the outside.
not sure on the gear box light.
Ok, thanks, ill have to check the power steering fluid then. Im not asking about the actual fog light button, ive got an aftermarket red switch in the side of the cluster, it doesnt seem to do anything.
