where can i get pair of this size brake disc but with drilled holes?
dan.:biggrin:
Are you looking for replacement rotors or are you just wanting drilled discs of the same diameter?
You could try Dan@DTA, Z1, CZP
Edited by Mikey
You Mean disc brakes, we are not American guys!
Nope, im pretty sure he means brake discs. :rockon:
Tomate-o, Tomato.
OK, this is going to be a tall order unless you know the exact make and dimensions of the bells. I've recently gone through this exercise for Sumshiftyguy with AP Racing and withouth having the actual rotors to work off it was a near impossible job to get replacements. With AP the problem is that they never did a 300ZX specific brake kit (other than for Stillen in the US and even those are not specific to the Z32). Basically, in order to find replacement rotors you'll need to know the following:
Bell mounting PCD
Bell bolt size (length, diameter and head size)
Thickness of rotor (ie 30mm, 32mm, etc)
Rotor contact patch size (ie, what is the measurement from inner to outer diameter)
Or, if you can spare the rotor and send it to me I can drop it by my local AP Racing dealer and have them examine it.
Let me know if I can help.
Regards,
Bell mounting PCD
Regards,
thats what i call service Dan:bow::)
:confused: This is the AP Racing 300zx Kit I have for mine : http://www.apracing.com/info/products.asp?product=%3Cimg+border%3D%222%22+src%3D%22http%3A%2F%2Fwww.apracing.com%2Fpics%2Fproductpics%2Fnissan_logo1.jpg%22%2F%3E-+300ZX+-+Front+6+Piston+Kit+CP5555T1000_1685_1054
Edited by Yowser
thanks for all your help, didnt realize it would be so complicated!:confused1: think once i get sorted i will send one up to you dan if you dont mind.
dan.:cool3:
dan.:cool3:
where they from Dan ? Are they part of some sort of Brake kit, or are they Just discs with Caliper brackets ?
lol they are disc's with the caliper bracket.
dan.:cool3:
dan.:cool3:
No problem Dan! Just let me know when you're sending one over (would be useful if you can also send over the bell).
Regards,
Dan
