Need Space
need space and so need to move engine oil cooler but the oil feed on the standard uk tt the oil feed comes from the bottom of the cooler and the pipe goes up 8" from the bootom to the top on inlet and outlet my question is can i recolate the oil cooler moving it up around 12" from were it was without causing any cooling problems.there will be much cooler where i want it to go but dont know if there is enough pressure at that hieght to keep the oil following?
i would say it will cause issues, but then again it might not.
I would pm zedworld or Jimmer, to find out the pro's and cons.
sorry not much help mate
See im thinking anlong the lines of a hose and water because using gravity once you have a pull from the other side then surly the iol would still flow although i would have to make sure with what side is the oil comming in and out
