May 30, 201016 yr that fitting is way off. the zed has a pcd of 5x114.3 the only way ud get a wheel like that to fit is to fit hub converters but that will push ur wheels out by at least 20mm
May 30, 201016 yr nope. You want 5x114 Offset depends on width. Ideal offset would be something like below, based on a typical 8.5" front and 9.5" rear : Front +20 Rear +35 If the widths are differnt then the offset will need to be different. An Offset calculator such as this http://www.1010tires.com/wheeloffsetcalculator.asp can help you find the matching offset for a different width. Its the outer position that you want to try and keep the same ideally.
May 30, 201016 yr Author that fitting is way off. the zed has a pcd of 5x114.3 the only way ud get a wheel like that to fit is to fit hub converters but that will push ur wheels out by at least 20mm So if i get hub convertors then know prob ? Where do i get these from ? I will not have a problem with them pushing out 20mm as i am going wide arse on the rear, will it be a prob with the fronts rubbing on the wheel arches if i fit the right wheel spacers ? Cheerz Chris
May 30, 201016 yr if you have 20mm spacers on the front with wheel offset of 38 you will be fine. Im running 8.5x19 rims (ET35) upfront with 30mm spacers and it ok. altho i am getting some rubbing because the front tyres are way to wide at 255 / 35 /19 also you will be better off having 235 width tyres on the front just to give them a little stretch you can get these converters off ebay. but it is harder to find converters that are 5x114.3 to 5x100 as most are 5x100 to 5x114.3
Will the bolt pattern 5x100 and 38 offset fit on a Zed ?
Cheerz
Chris
