When accelerating on a poor surface I've become aware that somethin is a amiss. The first time it happened I put it down to stiff suspension and a poor road surface but its happened a couple of times since. Not very often - but I generally dont cane it unless on a good road surface anyway. 99% of the time there's no indication of a problem.
When it does occur it feels like something isnt meshing correctly, either in the gearbox or the diff - or so I presume. Cant pinpoint it exactly - as I lift off whenever I hear/feel it happening for fear of damaging it further. It happens only briefly for a second or so, on rough or broken tarmac.
Am having most of the suspension bushes replaced at ZEDWORLD early next month, so while its there what do I need to investigate? I'm pretty confident its something to do with the transmission. One of the HICAS arms is being replaced along with the outer hub bush - is it likely that this has anything to do with it?
Easy guys
Has taken me a while to notice this one.
As ever, thanks for the comments/advice
cheers
