May 16, 201016 yr exactly (in every way) to this sounds identical, goes away when warm, im not too bothered tbh its not lost a drop of oil and its soo clean..... the last reply was 'I did fix it it was the oil pump cavitating due to a faulty oil pickup tube' wat? :D
May 17, 201016 yr sounds like a bearing on one of the pulleys to me... have you tried using a pipe or tube to your ear and poking around with it, to see if you can narrow down where its coming from? watch your fingers tho!
wat?
:D
