what mm spacers do you guys have if you have them!
hi everyone,
just about to buy some spacers to fill my arches a bit better. crappy halfords only have 9.5mm spacers. this doesnt sound like much!?
what would you recommend...
cheers
It entirely depends on how much you need to space your current wheels out by based on there offset and width.
If your going to use anything more than 3-4mm then you really want bolt on hubcentric spacers.
just put a ruler on your wheel (Outer rim of the alloy) and measure the distance between there and where you want it to be (Tight with the Arch lip or sticking out) then get the closest one to it!
You can usually get like 10mm, 15mm, 20mm, 25mm which should accommodate you no problem! All depends on what wheels you have on already and their offset
i have the stock alloys on at the moment and i want them to fit the arches neatly. im thinking about 15-20mm. thanks for the advice!
I'd say go for 25mm at the front. There's a huge gap on stocks. Get UK rears (which are wider and have a dish to them) and space them out around about 10mm.
