May 15, 201015 yr What is this cut off cable from mid section of the exhaust system is it important? I am still waiting for a workshop manual to arrive.
May 15, 201015 yr Cat temp sensors. All the sensor does it light up a symbol on the dash to warn you that the cats are overheating - which is typically due to a missfire issue with unburnt fuel entering the exhaust system.
May 15, 201015 yr No need to. Has no affect on the running of the car. They are often cut, typically becuase a mechanic/garage had to remove exhaust but could not undo bolt. They are also removed when people fit decat pipes.
May 15, 201015 yr Author Thanks that has put my mind at rest, I only need to worry about the slightly smokey turbos?!
