i've got a dead zed.... help
right took it for a drive last night was fine, then went to go to the post office today started fine, got less the 0.5 mile down the road and it started firing on 5 cylinders... its the 1st cylinder on the passenger side,i think it is still getting power, but not sure if its actully sparking,... and is getting fuel , but when disconnected it makes no difference, and on top of that there is now alot of smoke.....:helpsmilie:.. its white on idle but i can smell oil, and did appear slightly blue under slight revs...it appears to be holding temperature, so it cant be HG, and when i left home was running on all 6... the oil pressure seems normal too ????:cursing: really confused help
help, its come out of the blue I've had no smoke what so ever before, and ran perfect up untill today...
few more bits of info, its a 1990, TT lwb import, it does have a tiny oil leak, less then a drop a day, but i cant find it so never fixed it, ill do a compresstion test tommorow but had done the whole car and it was all good only a few weeks ago..
sounds like it could be a ptu fault. have you tried changing the coilpack with a known working one?
yeah changed the coilpack, have just noticed its sitting a a pool of oil, which is comming from the passanger side , looks like possibly the turbo...
so i guess thats it for my Zed its off to the great scrap yard in the sky...
would explain why that cylinder wont fire, its sucking in oil from the turbo...
