Oil & Water Temp Senders for Guages
As above guys any idea where i can get them from?
The Oil one that came with my guages is the wrong size....
Also the water Temp sender dosen;t have a connection for an earth only a feed is this correct as Neil (Darkside) who kindly fitted them for me seems to think it's not and it doesn't work?
Help?
surprised no one as replied to this.
i had an oil sender with my stack gauge but could not get it to fit as i needed a tapered thread adaptor, but it turned out i had a sandwich plate already fitted so it was no problem bolted to one of the ports on that.
the feed wire for the temp sender on mine just goes with the stock one at the front of the engine, gauges should have an earth, ignition live, permanent live and the feed methinks from memory.
