Steering wheel problem.. brain baker
Guys
When I bought the zed the indicators never cancelled when you turned a corner. This was solved when I bought a new wheel with the proper fixing kit.
Anyhows I had to remove the thick (already broken) double electrical plate thing that went on there with the stock wheel. With it on the new wheel would not go on the spline properly and the indicators would not cancel again.
Thing is I have wiring for a central horn and two thumb mounted NOS buttons to wire in. The problem is how on earth can you rotate the wheel 360 degrees one and a half times each way and wire them in without the nissan thingy???
I cant use the Nissan one even if it would fit and cancel the indicators, this is because even with the aircon It only has three possible wires and we need four.
Any ideas what we can do with this or any workarounds you can think of?.
try the coloumn and hub from a TT that had all the extras hicas/cruise etc would have thought this would have more connections on it
