rear calipers and disk width
I've got an s13 and instead of doing the usual thing of redrilling 5 stud disks and fitting either s14 or z32 tt calipers I took the easy option and fitted pre 96 non turbo z32 calipers on the front cos they run on 26mm wide disks same as the s13 instead of 30mm like the tt's.
Does anyone know if the rears are the same??
will the pre 96 non turbo's run thinner disks on the rear same as the front.
Cheers.
I think the rears are the same on NA and TT, 26mm, just the fronts thats different, hope i'm not wrong tho, but sure i read that in a recent post....
The 26mm discs were pre 1990 and not '96, the rear discs were the same for TT and N/A 297mmx18mm front discs post 1990 280mmx30mm
Cheers guy's.
So the rear disks have a larger diameter than the front??
Cheers.
Glad that all worked out!
Im pretty sure the Z32 rear caliper bolts straight on to the S13 without any mods. Unlike the S14 where they need the cables etc. Try asking the question over on SXOC.
Correct, need backplates and handbrake set up from Z to do an s14
