ACT clutch can it be used with
RPS billet fly wheel???
I have an rps max street clutch at the moment which is knackered and do not really want to buy a new fly wheel:thumbdown:
why is is nackard mate?
Looks like it has got hot and distorted fingers, poss due to launch control:sad:
does it slip? or is it vibrating?
Going on what you have told me. I don't think Launch control has been used since I sold the car. It's more than likely to have been caused by the previous owner to LEigh taking it to the nurgerg ring.
Does not slip or vibrate, but has no pedal travel! bites less than an inch off carpet and is near impossible to get into 1st or reverse
Good point Stu forgot that:thumbup:
The car has had issues with the pedal because there has been a nut welded onto end of rod to make up more travel i guess
How do i get bigger pics!!!
I dont think its the clutch. When they were or start to fail the bite real high. you might just need to adjust it or even bleed it. Check the fluid check the system etc
Thanks for advice Jimmy, will post up a picture of the clutch when i get home, see what you guys think:wink:
:cursing:removed clutch to get a better picture and unbeknown to me once you release pressure when undoing bolts the fingers go back to normal due to having no pressure behind them:crying:
Did the clutch force itself off the flywheel once the bolts were undone? This is a good sign the plate may be salvageable.Its the plate we need to see mate to judge if its had it.If your flywheel is an RPS syn r g then the friction plates can be replaced if they are buckled.Z1 sell the kit.
Never forced itself off the flywheel hang on will get pics
That clutch plate looks ok as the grooves have not gone BUT it is not able to cope with the cars power so will fry soon prolly.That flywheel is the same as mine.Set of plates cost $190 iirc.
