Has my ECU Died ????
Help Please!! !- just started the beast after the winter lay up - Started Ok BUT Rad fan is running all the time ( from ignition on ) and engine is only running on one bank. One exhaust sweet as a nut, the other just smells like a swamp rat. Have checked thermostat control which seems ok so could this possibly be due to damp having got into the ECU ?
It is a possible ECU malfunction/problem but are there any warning lights lit up on the dash?
Do an ECU diagnostics only takes 10 mins and it might pin point to the temp sensor for the ECU, which will need removing and a thorough clean at both ends.
smithy
Hi Smithy
Many thanks for your commets.
A look inside the ECU has shown up a corosion issue on a 1 ohm resistor which has been rectified and may hold a clue. I will re-fit the ECU and carry out the diagnistic check you suggested
A bad connection on the temp sensor will also cause the fan to run, it also causes overfueling.
Jeff TT
excuse me for being ignorant but r u talking about the viscose fan, the main fan on engine? if so that runs all the time? or have u an electric fan attached to your RAD??
No mate, it's the other side of the rad and can only really been seen properly with the centre headlight panel removed.
This will come on to quickly cool things down in the event of excessive temps, or in the event the ECU "thinks" it's high temps, hence cleaning teh temp sensor.
smithy
