while the engine is out, anything i should do to it?
its just sat round the back of my house (undercover) anything i should do to it before it goes in? its a ukTT
new temp valve, new cam belt, new tensioners / water pump / pulleys, new rear and front crank oil seal, new aux belts, water by pass, egr delete, new pipes.
Basically anything that looks like its going to be a pain in the ass to sort out at a later date with the engine back in. -
its had a new timing belt, aux + tensioners, dont fancie oil seals as its a low millage clean engine
water bypass?
egr delete?
this interests me, but why do i want to do these things? :S
Have a look at the search mate the water bypass was posted by JeffTT iirc lots of info on there plus the egr delete is on there too but this will clear up alot of pipework and hoses that are not needed
Marty
water bypass?
egr delete?
Water bypass on the upper plenum, so if you have a water leak on one of your pipes, its a lot easier to sort out at a later date, plus the added benefit of new tubing.
EGR delete, same thing, these can fail and when they do its a engine out job as its located right at the back of the engine, will also make getting the dreaded knock sensor slightly easier as the EGR sits in front of it.
There are a few threads up about it
where do you live again? :tt2:
I'm in the same boat dude, got a lovely complete engine to strip of its litle excess luxuries... :clap:
its not even on my land, just sat round the corner under a car cover in a castered bread tray..................... i cant get it up the step into my house..... jypsys were round 2 days ago asking for scrap metal........ :wacko:
i fancie the egr delete, cant find much of a walk through regarding the water bypass but ill keep looking, looks like i need some metal plates and gaskets making up....anyone got these ready made?
