protoj · Tuesday at 18:48 4 days
At the moment in our house (me and the other half) we run 3 cars and 2 bikes and pay for all the insurances individually. I am on the look out for a MK1 VW Caddy at the moment too (might have found one) and I'm thinking that there must be a way of having one policy that covers everything without needing to be a trader. Is there such a thing?
