Rev's sticking!!
Ok When The car is started from cold, rev's around 1500.
Once warmed up, the rev's will drop to 1200, and then to 800 when she wants, doesnt seem to be consistent.
She's an N/A if that makes a difference
Any suggestions.
Assume the above with aircon off!!
Only a first suggestion but have you got another maff you could try?
I've checked and cleaned the connections on the Maf, so it could be faulty?
I've also checked the filter and it's clean
Sticking air valve, bad connection on TPS ( hard idle switch error)
Jeff
Jeff
Thanks i will have a look
