help im a 300zx virgin with problems
CAN ANYONE HELP IVE BOUGHT MY FIRST ZX ON A BUDGET ITS A N/A AUTO WITH LOW MILES AND IN FAIRLY GOOD NICK BUT ONE PROBLEM IM HAVIN IS THE SPEEDO IS MEGA ERRATIC THE NEEDLE FLICKS UP AND DOWN AND SOMETIMES NOT AT ALL WHICH CAUSES SOME INTRESTING HANDLING ISSUES AT SPEED WHEN THE SPEED DEPENDANT STREERING PACKS UP
IVE CHECKED THE WIRING AND ALL IS OK AND THE CAR IS STILL RUNNING IN KM HELP I LOVE THE CAR BUT NEED TO SORT THIS!!!:cursing:
Probebly a dry joint on the back of the speedo. You can resolder to solve or replace the clocks.
Check the search button as this came up for a few people last week :thumbup:
welcome by the way :thumbup:
it will be the speed sensor on the box
get under the car and look on the side of the gearbox the drivers side i think.
the sensor is like a little cylinder about 30mm in diameter with a black plastic plug in the end. this plug comes loose and slides out causing the problems you describe. tap it back in andtap over the edge of the casing a little to stop it coming out.
should fix it
thanks for the help some good things to try and some not so helpfull (yes ive found the caps lock key didnt know i was being tested thuogh)
il try a look at the gearbox sensor
cheers
cheers
Baz doesn't mean anything personal mate, just caps are considered as shouting on forums :euro:
Agreed, there's always a bit of banter on here mate, all good natured mind :thumbup1:
Get some pics up of your car bud - we all like to drool over the mighty zed :bow:
Awsome baz , this place is full of frendly banter its what makes it feel relaxed and u havnt got to worrie about offending anyone.
cheers
Though :thumbup1:
Welcome
:thumbup::thumbup:
