NOS fuel rail questions
Guys
I will be very surprised if anyone can help with these but worth a try.
Today we ran the main feed from the tank in the back to the engine bay. Now you have to tap into the fuel rail for high pressure fuel for the system.
First question
As I have 300 degree fuel rails do I drill and tap a hole into where one of the partially threaded blank holes are. I believe they are for fuel temp sensor but there are two as they are designed identical for each side?. Reason I ask is they look very close to the edge of the rails and maybe you need to drill and tap a completely new hole?.
Second question
Where on earth did you mount your solenoids for the fuel pipe to reach the fuel rail. As the pipes that go into the hard pipes are not long enough to mount the solenoids at the rear of the engine?.
I have a proper 300zx kit, I had a look an Vinz engine pics but I cant have mine floating about where his are as I am not having a full cam cover.
