do NA De-cat pipes fit TT downpipes?
i wouldnt of thought so as they come off the turbo elbows! i think the NA pipes have a much less of an angle on them iirc!
i need pictures, think the na's might be more like a 90' angle at the downpipe end weather the tts look almost 45'
nope, wont fit,
i thought they were the same?? phnw ones are i think as i purchased some off of a tt owner!!
The are different, having just gone from a n/a to a TT I can safely say there is a difference, what I am going to find out tomorrow though is if you can fit N/A mongoose exhaust back boxes to TT cats, I'll let you know
i believe.......
from the cat backwards TT and NA are the same (but LWB is different to SWB)
the down pipe from the engine to the cat is obviously different between TT and NA
If your decat just replaces the cat, then they are all the same. if your decat replaces the down pipe and the cat then they must be different
[sIGPIC][/sIGPIC]
eeeehhhhhhhhhhhhh? so......... are they different or not...... just some pics will do :)
Go to zcenters website they sell after Market exhausts with pictures they clearly show the Decat pipes are different between the N/A and TT.
The TT pipes fit to the turbos and the N/A fit to the manafold, if I'm correct the N/A downpipes are 3 bolt fixtures and the TT's are 4, but I'm sure someone will correct me if I'm wrong.
there are different decat pipes around so unless you know what type you have we can't tell you if they will fit?
