Manual conversion?
Hi folks ive just had a look through the search and cant quite find what i was after. Im looking at getting a z32 shell that is a automatic and i will convert it to manual in the summer. Question is, is it just a case of bolt on all the manual gearbox parts, are all the mounting points there for things like the clutch master cylinder. Just wanted to check i wouldnt need any body modifications to convert to a manual.
Marty
all the fixing points etc. are there matey... you just have pop off a bung plate for the master cylinder to go through the bulkhead, and a little bit of wiring to do, there's a write up i think in the faq section...
oh just another point would the auto wiring loom be ok? im guessing it just has the extra connectors for the auto g/box but the rest is the same. Ecu plug is the same as well isnt it?
