protoj ·
Any advise on how to lighten my steering im sure its too heavy
Got UK clocks on belt looks and sounds ok pump sounds ok tyre pressure is ok.
steering wheel is a bit smaller and its running on 19's but it really is too heavy. Any help appreciated :thumbup:
