arrgh bloody brakes!
ok story so far since car been off of the road.
fitted tt calipers, braided brake lines and filled with dot 4 fluid. now the car has been sat drained of fluid for about 3 months.
started to bleed system and used manual guidance
left rear
right rear
left front
right front
abs front
abs rear
now i cannot get any bloody pedel firmness, still feels spongy but some resistance
. fluid running clear and bubble free at all bleed nipple points! what am i doing wrong or have i got an air lock somewhere still and have to go round the system again?
Very common for the master cylinder to give up the ghost in the middle of work like this, nothing you have done wrong usually due to the age of the inner components.
Try re-bleeding once more at any point and see if air bubles come up through the resevoir, if so a clear indication air is been drawn in at the back seal.
Jeff TT
