June 17, 200224 yr Do a search on 3 g brakes. http://www.3gbrakes.co.uk they do brembo stock size oe replacments. cheaper than nissan as well. ------------------ YOU LAG YOU DRAG
June 17, 200224 yr Depends on what sort you are looking for? Drilled? They crack! Tarox - Grooved/Slotted? They warp! Sejoc.co.uk - EBC front slotted/dimpled brake discs (gd695) Nissan - standard - £85 each. Brembo plain discs - Zedworld.co.uk £220 fitted. Cryo Treated? - my next ones will be these as my Tarox are shot, on order from Paul at Whifbitz.co.uk - £98 each. Matching the correct pads to the heat capacity of the discs is important to stop warping. ------------------ "Polished on drive" "Dirty at 156mph" --------------- Z first and anything else is secondary and live life a quarter mile at a time! John Newcomb (NukeEm) www.geocities.com/jn300zxtt
June 18, 200224 yr ill add to the above black diamond== warp £70 from motor factors grooved and drilled have been fine for me for the last year
where i can find rotors at a good price for the standart calipers???
