Problem with headlights
Zs been garaged for a couple of months. Took it out tonight and had frightening problem with headlights. All seemed well on dipped headlights, went to full beam - still fine. A few minutes later, switched back to dipped and had no headlights at all!!! Flicked the stalk a few times - full beam always reliable but dipped only returned one time in 4(ish) flicks, the other 3, no headlights. The only reliable way to return to dipped lights seems to be to pull the stalk right up (headlight flash) and when I let it go, I have dipped headlights.
Too dark to look tonight - will try tomorrow. I'm guessing it's the stalk. Sealed unit? Any way to use contact cleaner? Easy replacement?
Any ideas gratefully accepted.
Check the relays in the large fuse box in engine bay black and brown.
Or remove the pod housing the lights, and check wiring. It held on with 2 x screws at the base
