Gah! Wipers, clock and pod dead
Hi guys,
Just had the steering column off to try and fix an ongoing steering prob (hopefully fixed now) but on starting up it appears I've lost the above mentioned electrical services. I disconnected a few bits and pieces to make column removal easier and just wondering if I've not connected something back up. I can't see anything loose that should be connected apart from a second, 3 way connector from the ignition switch but Can't find anything to plug this in to :-(
The odd thing is that when I first turned the key, halfway through reinstall, I'm sure the pod was working.
This car is seriously beginning to do my nut in, I get 2 new problems for every 1 that I fix!
Any ideas?
H
i get this sometimes to never found out what it was seems to only happen to me in really cold or wet weather only happened about 3 times though
I'm starting to suspect the ignition barrel...
Fixed! Looks like an ECU reset sorted this, think it got screwed up with me operating the ignition without all connectors in place. I erased the ECU RAM using Consult
H
The problem you had was part of the aux 1 or key position one power supply, this can be the ignition switch or faulty fuse box but not in any way connected to the ecu, guess the problem has sorted itself for now, will most likely return, if it does when wet its the fuse box for sure.
Jeff
Double Gah! It's back again! I didn't even get to drive the car before it came back...Like you said Jeff, must have been a fluke that it magically started working again.
So what's the drill? Pull the main fusebox in the footwell and dry it out or remake connections? Beautifully positioned item - thank you Nissan!
Cheers for any advice....
H
Sorted (for now) it was the blue relay behind the fuse box.
H
