Front hub removal
Just a quick question. To remove the front hubs do you simply have to unbolt wheel bearing lock nut, located behind the front axle. Then pull the front hub out?
Regards
Kev
You'll need to split the top and bottom taper joints aswell.
I am currently updating the suspension setup on my car. Plus, fitting bigger brakes. Rather than bodging the brake deflectors i want to remove them properly. So i thought remove wheel hub then pull the deflector off. Will it pull of or is it welded in place? Do i still need to remove top & bottom tapered joints?
If so where are they located, not shown on manual ie picture above?
Edited by toftdale
