protoj · Tuesday at 18:48 2 days
Has anyone painted their scuttle panels at all. I dont want any gaudy colours just a nice matt dark grey. Do the panels accept paint ok and is it better to rub down with very fine sand paper first? is it better to use lacquer to protect them?????:wink:
