Steering judder under breaking
chaps i have steering judder when breaking :cursing:
i have energy suspension tension arm bushes i would say about 7 years old now do these wear out? or possibly warpped disks im using 324mm brembos with std calipers i doubt there warped but never know
any ideas anyone
cheers :drool:
As above check discs and pads first! May get lucky and just have uneven pads but most likely the discs
ive got same problem, i got standard discs though so probably that, if you can borrow a mot garages rollers (brake tester) it should show up the discs being warped on that i would of thought?? whereas loose bushes would only show up on the road? this is only my opinion though!
More than likely the Disc's are warped......
.....new discs should resolve your problem.....
I know alot of Garages (Mainstream) do free brake tests but its whether or not they allow you to leave without getting new stuff fitted if its f**ked is another matter
sometimes it can be heat spots on the discs...... you could skim them but might as well buy new discs. how does it judder? always on the brakes or after they have warmed up?
my discs suffered a bt of juddereringbut only when they were hot so i took it out for and performed a bedding in session up to 60mph then braking down to 5mph about 10 or 15 times, when they start to fade i let off and drive for 15mins to cool them down, brakes feel great after that as the pad has left a nice layer on the disc which is what you want....... if yours are warped then what ive just writen wont mean crap lol..
