Cruise control and a knocking issue...
Is this easy to retro fit...... if so what is needed....
Also there is a knock on bumps from the front right side. is this track rod ends or top mounts????
its probably whatever is worn ;)
theres a lot of suspension bits down there.
Thanks!!! Helpfull that... :tt2: Is there any common parts that go?
apparently not easy to retrofit, i wanted to do this to mine, you would need cruise control stalk / steering wheel (depends on age of car) cruise ecu, pedal switches, wire and mechanical gubins from under bonnet, and a wiring loom
most likely bushes leaking on the track rod end
[sIGPIC][/sIGPIC]
On my zeds in the past its been the camber arms or the lower arms, but it really could be any of that lot that is fitted down there. Best bet is taking it to a garage or get it jacked up and check for play in everything.
