Oil pressure, Turbo psi and ......................Engine temp?
IMO :smartass:
Oil Pressure, Coolant Temperature and Boost Pressure (PSI or Bar.....personal preference)
Oil Pressure, Oil Temp, and Water Temp (Also known as Engine Temp)
You could also do Boost (PSI or BAR) EGT (Exhuast Gas Temp's if your into Tuning)
Rest are waste of time really although ,may have forgot an important one.
Apexi Power Meter :gunsmilie::gunsmilie::gunsmilie:
not that you'll find one lol. :wacko:
.......volts are handy.
Yeah, it's handy to keep an eye on that.......eh Yassa?
OR , heart rate BPM, blood pressure SP and sphincter pressure :w00t:
sorry :lol:
Daz :lol:
Meat temp gauge:wacko: I've got a 52mm one if you're interested. Or a bling gauge like BG Vinz has :laugh:
Is that your`s Bazza :tongue_smilie: I want !!!!
DaZ
Water(engine/coolant) temp is always the most important aftermarket gauge for the Z !
after that I would go Boost pressure (especially if you have increased boost) and Oil pressure.
i got water temp, oil pressure, oil temp and the profec b does the boost pressure and the turbo timer amongst other things does the volts!:thumbup:
dan.:tongue_smilie:
:lol: at least it gave some people a work out in the morning.
i have oil pressure, boost and water temp
water temp, boost pressure, oil pressure
...if you have an EBC then you will be able to read boost from that, and a lot of other gadgets can display some important stuff too (the Apexi Turbo Timer displays Volts and AFR)
