Near side rear light out??
Hi Guys, just a little problem, which is annoying me?
My rear near side light is out? brakes and indicator work ok, just the 2 red lights dont work, I`ve swapped bulbs and even swapped the bulb wiring loom over and its still the same?
Any suggestions
Thanks in advance
Daz
Any suggestions
Thanks in advance
Daz
Common issue Daz, the lights alert module has failed on that side, often but not always caused by a short when changing bulbs or tapping onto the circuit incorrectly.
You have two option:
one replace the module which is located on the rear of the drivers side rear light, normally clipped to the outer edge they some times are unclipped and are hanging down on the loom.
Two link out the offending circuit at the module, just identify the cable which needs linking with a voltmeter and link using the same size cable.
(If you want the actual cable colours for that I can check them for you)
For your info the modules go for around a £10 unless someone here has a free one for ya.
Jeff
Thanks Jeff, you really are a star!!!
BUT, I`ve just changed it with one from my scrapper and i`m getting full brake lights on now??? and the little red dash light is on?? Have i got gremlins?
that silver one looks nice for a scrapper :lol:
:D It nearly was a scrapper today!!! I took her out for a blast today and she nearly killed me!! I forgot about turbos :punk:
Daz :biggrin:
