Hi spec pc games
new call of duty?
dont do allot of gaming on mine now, go to a good shop though and take a peek at the spec's on the back of the most modern games
WoW needs more of a fast internet connection as long as you have a half decent pc it has no problem running
Oh not, not another one going to the dark side (world of warcraft), like said above, you only need a fast internet connection, in raids (40 man etc) you will need quite a bit of processing power, ram and a good graphics card, personnally get a Core 2 Duo, about 4GB of RAM (DDR2) and a 9 series (Nvidia) or above graphics card
If you want a game that's going to test your graphics card and PC set up in general, then you will be hard pressed to find a better game than CRYSIS or CRYSIS WARHEAD.
If you want a game that will test your processing power, then get GTA4 as it relies more on CPU than Graphics card.
Crysis is a First person shooter, and if you can run that maxed out, you know you have a beast of a system.
Not to mention an awesome game as well :cool2:. Crysis Warhead isn't quite so hard on your pc specs as the original.
FarCry 2 is visually great but I got bored with it quite quickly. Got fed up having to clear the same checkpoints every time I went by them.
