Some advice
car seems down on power like turbos are not coming in even though its showing good boost levels , from low revs the car is slow to pic up speed and revs ANY IDEAS lads and gals :taz:
Boost leak by the sounds of it, go round the engine bay chap and tighten everyting, listen for leaks, maybe an intercooler pipe
could also do an ecu check see what error codes come up, your car maybe in safetyboost.
how do i get her out of safety boost its boosting to near 10psi on the guage
Do an ECU check instructions below, find out if your getting any error codes, as it could be a prob with your dett sensor that will put you straight into safety boost.
http://www.zmods.org/index.php?page=ecu_diag
also check all pipes for boost leaks
hopefully it will be something simple.
cheers Craig
