Changing a offset.
My wheels have a really large offset or is it small offset
Anyway they stick out the arches.
Is it possible to change this offset so they don't stick out so far?
This will involve cutting the metal centre down on the inside of the wheel.
These were expensive made to order 3 piece wheels, is this a good idea even if it is possible?
Obviously i wouldnt attempt myself and would take to a specialist but where could i take them?
What wheels are they?
Yes, it's possible but that depends on how much 'meat' is left on the mating hubs and how much you want to reduce by. It will need to go to a quality engineering shop who can skim the face for you or mill it down on a lathe.
They are Blitz Type 03.
They hand out the arches on my Zed as i was intending on fitting a wide arch kit.
Pretty sure they will hang out the arches on the NSX also. Wouldn't want to wide arch or flare the arches on the NSX so hoping i can get the wheels to fit.
Would i need to get the tyres removed?
Would it be really risky damaging the wheels?
I think they are...
front
235/40/18x9 et35
rear
295/35/18x10 et22
i take it the rears are the trouble?
yea just go to a good machining shop, shouldn't be hard for them to do.
Check how much meat there is where the wheel nuts sit, this will be the deciding factor.
Paul
It's also worth noting how much space the caliper takes up. If you get too much machined off, the caliper will hit the spokes.
