Wheel offset question
Hi can any of you wheel lovers out there tell me if this offset would fit or look anygood.
Fronts 225/40/18 offset 44 Rears 265/40/18 offset 30
Dan
fronts will stick in a bit, rears will be tight. you might wanna use a 265/35/18 as the 40 profile will be a bit fat.
Well the fronts will look poor and those tyres won't look too cleve. 225 on an 8.5" wheel is a really stretched look (ideal if you're going for a really whacky offset with the car dropped on its ass). Rears a little better, but you want to be running 275 at the back ideally with a 245 at the front.
Your front offset isn't ideal. Wheel will sit waayyyy too far inside the arch. But a set of 25mm spacers will kick them out to give you a +19 effective which will give a nice flush appearance. Rears are about ok. Ideal is +35 on a 9.5" wheel, you may have to roll the top of the arch ever so slightly. But nothing extreme. You might actually be better off with 265s in that case. But certainly the fronts, 225 is too narrow (tyrewise).
Thats my offset:D.lol!
I do have a set of 20mm spacers at home i was planning on putting up for sale soon aswell. i was going to fit these to the front wheels of the car.
Ok thanks for your quick replys guys! :) Think ill have to pass on these wheels
No they aren't! You fronts aren't +44! I guess you're referring to the +30....and offset means dick without a width. ;)
Nooooooooooo:(
