My HID kit from DTA arrived today (thanks Dan) and assuming it's dry tomorrow, I'll be fitting it.
The instructions look OK but pics would have been nice. I'll definitely be taking some tomorrow.
Question : Where is the best place to put the ballasts and what should they be secured with?
i have slotted mine just in behind the lights. Havent secured them to anything as they are snug in there. I looked at other places but didnt find anywhere that i liked. I can get a pic tomorrow if you want?
A pic would be great. Thanks.
BTW, I also ordered some LED side lights. I'll have a look tomorrow morning, but how do I get to those? Is it simple or elaborate?
It is simple. Remove the bumper indicator units (2 little screws and pull away - you'll figure it) then you can access the side/fog unit from behind. There are 3x10mm nuts holding each light in. Remove these and the units will come out. Unplug the harness then you will need to split the lights (4corner screws) to get access to the bulbs. Make sure they seal together again ok to stop water getting in. (I bought new ones).
Best place to mount your ballasts is under the nose panel. The wires are JUST long enough to reach there and the mounting plates are perfect to fit some existing holes under there so they just bolt down. The panel will just about go back over again and jobs a good un. Perfek! :cool:
Sidelights are a peice of piss, follow the above instructions as it is no different to changing them for normal sidelight bulbs.
Isaac :D
