Plenum Pull
Hi guys,
Already read the how-to guides on here so no drama there, however I'm a little apprehensive to be honest. But the job needs doing so going for it LOL.
Is there anything that might/will break or will need replacing? I'm putting new rocker cover gaskets on. I have a new plenum gasket to go on and will do spark plugs at the same time.
Any hints and tips will be most welcome.
Cheers all, Rob
I forgot about the knock sensor wire at the back of the engine snaped the wire in two. But for my 1st time went very well. Also I did the water bypass at the same time.
it`s a lot easier to replace back on the block plenum if there`s two of you, i had to kneel on the front of mine cos kept moving the gasket,you could always superglue the corners though.
