since zedworld looked at my zed yesterday it splutters when i press the throttle before pulling off fine, they moved the tps so like a dick i just moved it again and now it idles at 2000 rpm, i put it back were it was and it still idles high what have i done :headvswal
You have lost the closed throttle signal, not a biggy just need triming back a little and then resetting. Look at the top screw, and the slot that the tps moves across in, to the right of the screw you will see a faint scribed line on the slot.
ย
Now adjust the tps so that the slot is in line with the right hand side of the top screw and tighten up.
ย
Start the engine and let it settle, disconnect the tps lead, the one that is on a fly lead not the one plugged directly into the front, leave it disconnected for 20 seconds or so and then plug it back in, hopefully this will give you an approximate setting with a closed throttle and a better idle speed, as your close to us pop back when you want and will check it through again.
ย
If in any doubt call or mail me and will go through it in person with you.
ย
ย
Jeff
:bow:i just did what you said and its sorted it thanks mate:bow:
ย
You welcome matey.
ย
Jeff TT
