In memory of Mandy
Nissan Conzult
My conzult box keeps flashing green, anyone know why it isnt going to red like it is meant to?
Hi Murt,
Could be a few reasons. Can you check that all the pins are making good contact with the diagnostic plug - sometimes one gets bend or pushed back too far to make contact.
Otherwise I hope Eric (Lymon) will chime in with his words of wisdom.
Regards,
Hi Murt,
Regards,
Thanks for the reply dude :) I will have a looky in a few.
the meaning of the LED's is described in the document that comes with the conzult package:
The communication interface cable has 3 indication LEDs.
Power LED
This is a green LED that will light up when:
- the interface is connected to the car
- the ignition is turned ON.
Control LED
This is a blue LED that will light up when:
- the interface is connected to the car with the DDL connector
- the interface is connected to the serial port of your laptop/computer with the serial cable
- the ignition of the car is ON
- the conZult software is running
- the software is accessing the interface
When there is no need for the software to communicate with the interface the blue LED will turn off after a few seconds.
Transmit/Receive LED
This is a dual color LED. This LED will light up in yellow or red when there is data communication between the car/ECU and computer.
