pfr6b-11c in a non turbo?
would there be a problem using these plugs in a non turbo z.
im looking at changing the plugs for when i get the z back on the road and have noticed that it currently has pfr6b-11c's in there. would i get more benefit from using a dedicated plug for the na??
Those plugs are just fine and will cause no problems in your non turbo, in fact they must have been changed from the originals so most likely best to leave them in if they are in good order
Jeff TT
Jeff TT
thanks jeff that good for piece of mind. i only checked the first front one so will check the ones under the balance bar to make sure they have all been changed.
cheers
gaz
