hicas removal
Just a quick question guys ive got a driftworks hicas eliminator kit but mines the electrical type so the question is do i just disconnect the rack and remove the hicas bulb or is there something else i have to do
Also would running 19's on kyb's and eibach springs give a harsh ride ta muchly
Jim
Is it the kit that replaces the hicas arms or do you still need to use them? reason I mention it is the later arms used a bigger diameter arm and hence a different thread??
Jeff TT
Eibachs are notoriously hard, so adding 19" wheels will reduce the ride comfort further.
You want some amount of compliance on our roads as the surface isn't fantastic. Increasing the rigidity too much will loose this compliance, preventing you from putting the power down effectively.
well mines running on 19's with eibach springs (tokico shocks IIRC) and i've got to say the ride isnt bad at all and the roads round my way are shocking.
Jeff TT
I remove the complete unit arms and balljoints in the hubs jeff
I think i will stick with 18's i did notice the ride was a bit harder when i went from 17's to 18's right enough bud
