Chrome Door Handles - Hard Part Done!
Called Nissan but they said these parts are no longer supplied and cannot be ordered.
So tried the local scrap yard and amazingly they had a Terrano II in. Even more shocking was the fact that it had 2 chrome handles still fitted!
Lucky or what?
Removed both handles (still in plastic housing). £20 for the pair.
Would have taken any others if available to help out any other members but will keep on checking regularly as I know most people want them!
The question now is: how do I fit them? The handle seems to be secured in to the surround by a pin that seems to be embeded in to the plastic. Any advice before I start to destroy the thing?
Thanks Si.
Yesterday, Turbocraigy stated:
NOTE: you do NOT have to remove the door cards to change these. It is a little fiddly, but not difficult. 15mins per side maximum, but be sure to have a good look at the set up to make sure it all goes together as it should....
I did mine without removing the door car, cant remember the exact way now but I know it was self explanetary once I got started, took 5 miutes to do both sides.
Thanks. I'll try without removing the door card firsts as I don't want to break any clips etc.
If I fail, the door card comes off.
you replace the whole unit not take the hadle away from the plastic (bit with the pin in!!)
its a total swap unit.
as stated above its VERY easy to do :)
