protoj · Tuesday at 18:48 3 days
Yup that's right. My tyres are catching on the arches, so I need a way to stiffen/raise the rear end. I have just bought these tyres so I'm looking for the cheapest & easiest route.
I have fitted some G14 spring assisters but they don't lift enough.
