Changing the oil in the diff?
How do you flush the oil from the diff? Also what fluid do you replace it with?
Any help/advice greatly appreciated.
cheers
dave
You dont normally flush a diff. If you think it should be drained and refilled then there is a drain plug. It takes a lot of oil as the UK Euro one has an oil cooler as well. Check the online manual for the correct grade and quantity to refill it. There is a filler plug that is the maximum level also. Make sure the car is reasonably level when refilling as you could overfill it which can then lead to seals going due to pressure from oil churning.
**TIP** Always undo the fill up before the drain.
Jeff TT
