engine help please
i have an engine been built with ross forged pistons
i have taken it to pieces and was looking at rebuilding it
the pistons are in great condition so was gonna get new rings and reuse them
how much roughly would it cost to rebuild and what would i need and what could i re use.
rings [get new]
bearings[get new]
gaskets[get new]
water pump[get new]
timing belt[get new]
oil pumps in good condition could i re use it
[have 555 injectors
and reconditioned stage 2 turbo technic turbos]
bigger side mounted inter coolers
if did rebuild it what sort of power could i get from parts above
If you did it yourself you would part with around £750 ish parts then another few hundred for honing,head skimming and valve work.The set up should see you around the 400-450hp mark i should imagine depending on mapping and boost run.
thank you for advice
where is the best place to buy gasket set only 1 i could find is on ebay in america
