did a compression test today.
i think all is well
all drivers side was 12bar- 176psi
all passanger side was 11bar-160psi
i think my timing belt is out as the cas is adjusted to nearly the end of its travel.
i would hope that after changing the belt they might level out? as one bank would be running more overlap hence a lower compression. make sense?
if the head gasket had failed i would expect either one or two cylinders to drop
im trying to make sure the engine is 100% before i tune it.
im also visiting zedworld next saturday so i am trying to do as much work as i can so that less of his time is wasted trying to pin down my running faults, the main one being its running very rich which costs a fortune in petrol and is not giving great performance. idle is lumpy too
