zedworld delimit chip help
Hi all i need some help to put in my delimit chip in cos zedworld did not send me the wiring diagram for it. If any one knows where i can see one on the net or tell me how many thanks
Not sure on the green or grey, mine was done upon purchase sorry but am sure someone will now poss groover? , have you tried calling Jeff also ?
The green replaces the violet in the description, iirc the grey can be left off, its a signal for something else, which im damned if i can remember at the mo, its been so long.
If you bought it off Jeff then he will be able to tell you exactly
Graham
  • 3 weeks later...
i have been on the phone to zedworld and asked him to email me and send it out and i have still not got the wiring info plz can some one help me i need to know so i can get my 300 done plz plz help
Red cable +12 volt
Black -0 v
Green To speedo input
Yellow To Speed sensor
Grey Not used
Identify the green / yellow cable on the rear connector to the speedo cluster.
Follow this onto the pcb board, the strip of copper can be cut with a sharp knife, on the connector side of the cut solder the yellow cable to the strip. That leaves the other 3 cable to be connected using the screws that are in place connecting the speedo unit to the board.
There is a 12v (red cable) 0v (black cable)and speedo input (green cable) this are marked on the pcb.
I will post a photo here tomorrow to show this in detail.
Jeff TT
