Stereo : No need for external antenna
- Replies 29
- Views 2.2k
- Created
- Last Reply
Shamaz Majid 5 posts
Daves_Zed 3 posts
Uno 3 posts
bantambunny 3 posts
- No registered users viewing this page.
The external antenna on my Z is broken, so when I read on this forum that there are actually 2 antennas installed (1 internal on the rear screen and 1 external), I decided to investigate. I know it sounds incredibly strange (why fit two?) but it's actually true, certainly for my Z.
When you take the stereo out, there is a black cylinder like object, from which there dangle 2 cables with plugs on the end. 1 is the typical plug that we all recognise; this goes to the external antenna. The second is a very thin version and is connected to the internal antenna. All you need to do is pull out the back of the cylinder (secured by a clip), turn around the 2 prongs and push the back back in. You will have to pull the clip out slightly to push the back in but it's no big issue and is still a snug fit.
Switch on the radio and voila! Works perfectly. No need to replace the external antenna. It's actually a much better solution than replacing the external antenna as I'm not sure a long thin old fashioned aerial looks very good sticking out of a low slung Z.
Apologies for not taking any photos; forgot to do this in the rush to make the changes between finishing work and the sun going down!
Will certainly take some the next time I have the radio out as I still need to work out why no sound from the rear speakers...
Hope the antenna stuff is useful anyway.
